Trans maintenance
The manual specifies atf+4, but we just had a discussion on using something different. Go to the vendors section, dynamic transmission. If you don't know the last time your transmission was serviced, or it's been 50,000 miles, good idea to replace the filter, governer solenoid and pressure transducer and weld a drain plug on the pan or get an aftermarket pan with a drain plug. A drain and refill will suffice.
This man knows his stuff when it comes to transmission work. I highly suggest you go over there and talk to Dynamic (Jon) anbout your servicing you transmission. Jon will guide you through and explain rather well on what you need to do.
