Thermostat temp
On June 20, 2016 at 0:04 PM, Mopar1973Man said:
Take notice to my coolant gauge here I've marked the green area as normal. You can see the open temperature of my thermostat. So I would have to say your thermostat is sticking.
Heater core is going south if your smelling anti-freeze in the cab. Most likely got a small crack and the expanding coolant with pressure is force out a small crack or pin hole.
Highly suggest a fuel pressure gauge. Most idiot light come on way too low. Like my old Cummins low fuel pressure would trip at 3.5 PSI. You need to be able to keep 14-20 PSI optimally. 10 PSI is stock low fuel pressure limit.
What monitor or programmer are you running?
15 hours ago, Mopar1973Man said:
Close enough. 165 and 225 is the actual numbers.
Hey now.....those figures I posted were from your findings a few years ago based on your high techy machinery.  Dont go changing things up on me now..... :think:
