- Replies 19
- Views 6.2k
ohioboy 11 posts
Mopar1973Man 3 posts
JAG1 3 posts
jlbayes 1 post
I went trough all connections to include grounds, all tested good so I put elec. Grease on all connections, pcm, and relays. As a last resort I pulled the plug for the crank sensor and what do ya know
Resistance is normal. Hall effect sensors typical have a coil inside with a magnet. So every time the tone wheel tooth pass it creates a sine wave. So if you put you meter on AC scale in the mV range
I am new here to the site, but I am having an issue with my Dodge. I had some issues starting my truck, when I turned the key over lights would come on and truck would start but showed no voltage, and abs/ parking brake lights on and gauges showed no voltage or tach, oil pressure nothing. Next time it would just click when the key was turned over, tried again a few times and it started. So I decided to test my ignition switch and found it to be bad, no voltage when the key was turned to start. Fixed the starting problem or at least i thought so. Now my GEN light is on, wont shift out of first, and my voltage is staying at 12v until engine warms up to 180 degrees then, shifts 1,2,3 but GEN light is still on and voltage drops to about 8v. Alternator was replaced and checked, batteries were charged and load tested everything worked out fine once replaced, next day same issues. Now it wont start again, tested ignition switch again, and its bad...again..Any ideas?
By the way the vehicle is a 1996 Dodge Ram 2500, 12valve Cummins, A/T, 4x4.
Edited by ohioboy
