Dana 70 yoke play
I have play in the dana 70 when you move the yoke back and forth. It measures about an 1/8 inch  worth of movement total is that to much. What is the max for the play.It regularly has metal on the dip stick in the cover. 243k on the clock.
Edited by jigdog
1 hour ago, Wild and Free said:
Sounds like you are good to go, that is normal gear lash aka back lash and is about right. What kind of metal is on the magnet? it is normal to have some very fine greasy type material on it as long as there are no large flakes or chunks you are golden.
Ok I will check the stick and see what it looks like thanks for the help
