Hard Start if at all, lots White smoke, has new vp44 & injectors
Buddy of mine has 1999 dodge truck, 5 speed 4x4. He replaced the vp44 & installed new injectors, the vp44 had failed, had that 16xx code, can't recall the exact code. The truck is hard starting, if it starts at all, if it does it idle's smooth but blows thick amounts of white smoke (i'm assuming lots of unburned diesel fuel) and the pedal is dead. White smoke does not go away.Several things I thought of vp44 installed wrong (timing key), injectors and/or connectors torqued wrong, over flow valve ???? I'm grasping at straws here, any suggestions appreciated.Thanks in advance.
  • Replies 8
  • Views 6.7k
Really good idea... White smoke is a good sign of retarded timing.... Did you install the right key? did you install it in the right direction? Did the key fall out during the install? As for the injectors... The only thing I can think off is a failed injector(s) that cause white smoke but since there new I'm going to fall back to the VP44 key...
Any code's
No new codes since replacing the vp44, my buddies friend cleared the codes prior to working on the truck, and of course did not write them down.
Are the injectors brand new ones, used ones from someone else, or did you/someone put new nozzles on the old bodies? If not brand new have they been pop tested?
They are brand new, I believe from BD Diesel 75 hp rated (not sure what the 75 hp means).
Means they are rated to produce 75 hp additional to the engine, so if the engine was rated at 215 hp with these injectors it is rated at 290. Theoretically - actual hp gain depends on a number of other factors as well.
You also said dead pedal.Did the injection pump connection click when installed?Did you unhook the cam sensor with the pump install?Did you check to see if the apps is hooked up?A 99 have a crank sensor what about that?
