Ordering replacement steering soon
AH64ID
  • 4 months later...
  • 3 months later...
Which track bar bushing did you use? I am due for a new drag link and either different track bar bushings or a new track bar. I did Lukes links track bar bushings from Genos over a year ago and they are junk, the axle moves about 1/2 inch side to side and then it bangs at steer lock while doing short slow speed maneuvering when the axle decides to snap side to side. The passenger side track bar bushing has a ton of movement in it. i have even taken it out to see if the bolt and bushing match size which they do but the bushing itself is too soft and allows for a ton of side to side movement, the driver side moves a bit but nothing in comparison to the pass side.
Edited by Wild and Free
