So anyways I fired up my rig this morning to go help my buddy put a lift kit on his rig. About a mile from my house the check engine light came on:banghead: it was bugging me all day. Got home and scanned it and it is a p07020. Output speed sensor is what it said. Where is it at and is it an easy fix. Can I get this part at NAPA. ????Thanks in advance.Luke
  • Replies 4
  • Views 1.8k
The only speed sensors i know of is one on the tranny and center of the diff on the rear end.The 0500 i think is the rear end one.You may look into the tranny speed sensor.It is somewhere around 1 inch socket.Napa has them just a guess at 40.$$.Mine was broken on transport after a rebuild.Bummer because it was new.It was 1 year ago or so.I dont remember being real mad about the price.
So anyways I fired up my rig this morning to go help my buddy put a lift kit on his rig. About a mile from my house the check engine light came on:banghead: it was bugging me all day. Got home and scanned it and it is a p07020. Output speed sensor is what it said. Where is it at and is it an easy fix. Can I get this part at NAPA. ???? Thanks in advance. Luke
I'm going to assume its a P0720 code??? So yes you should be able to get the sensor at your local part store.
Yes Sir. 720 is correct. My bad. Anyways I picked one up for 18 bucks at napa. Problem solved. I did however notice there was fine shavings on the tip of the one I pulled out. Maybe these shavings were interfering with the operation of the old one? Luke
Might have??? But know since you got a new sensor and the problem is solved I would hang on to the old one and lean it pu and see if you need a new one in the future maybe it will work for ya...:thumbup2:
