Differences in Dana 70 and Dana 80 spider gears
So I thought I had exploded my rear but when I popped the cover off I had only just busted the cross pin for the spider gears is their any difference in the spider gears and cross pin between the 70s and 80s? Because I cant find a 70 for decent price
Randy's ring and pinion, yukon axle.  They would be my first calls for parts.
If you broke a 70 and have access to an 80, put the 80 in.  I broke a 70 and if you are horsing around enough to break spiders, you are likely about to twist off an axle as well.
