- Replies 8
- Views 5.3k
mossyoak71 4 posts
Mopar1973Man 2 posts
Hawkez 1 post
trreed 1 post
Well time for an update. All I can say is GOOD GOD ALMIGHTY!!?. This build was amazing and fun, although I had some issues along the way, it was worth every penny. I have changed the injectors to DAP
If my 2nd gen every got wrecked and the motor was ok I'd do this swap in a heartbeat. I'm thinking 07 F350 King Ranch...
Sorry, I have to set up the notifications. Total project time was around 250 hrs. I have finally gotten it running right. I still have the front driveshaft to install, the AC lines to make up, ladder
Well I have built the truck that I want. After looking at a new 17 F-250 and seeing the sticker 70k, this build is finally happening. So bear with me while I try and describe it. I have a 2004 F-250 4x4 that had the six oh in it. That's the primary vehicle, I purchased a 08 F-250 that was totaled for the interior, dash, and tranny that had just been built by Revmax. I knew the owner of the truck and sent him there. I also purchased a 02 Cummins for the build, and a 07 Ford F-250 front clip. So for the interior, in order for the dash, climate control and gauges to work, I swapped the firewall. Also swapped the complete wiring harness from front to rear and the computer. The 02 Cummins had some treatment too. Starting with a rebuild, it only had 93k on it. Billet squirters, ARP studs, 110# springs, Glacier Diesel intake and heater delete, Rihno intake horn, Fummins twin turbo kit, Injectors DDP125, new VP 44 pump, FASS titanium 150 fuel system, and Quadzilla tuning. Also forgot a mishimoto intercooler. The frontend is 07 frontend with Harley headlights. Truck is complete, but having issues with throttle. It will only get to 1850 rpm and then acts like it has a governor. The original ECM was a manual one. I sent it off to have it reprogrammed due to a massive lope. It fixed the lope, but now will not go over 1850. So I bought an automatic apps and installed it, it seems to act better, but still only 1850.
Edited by mossyoak71
Wording
