Valve Spring seller?
On 9/29/2017 at 8:03 PM, Dieselfuture said:
I'm starting to think there were different size crank shafts too, as I did a front seal on a 97 I had and bought the seal from cummins by engine number and it was too tight. And @Cronus577 got a rear seal for his truck and it was too loose. What are the odds.
That would be on Cummins. I'm talking on the Dodge side of the court.
I didn't see the other thread. Off the top of my head, it should be a direct swap. Use the rubber flex line from the disc truck. You may want to swap proportioning valves and/or master cylinders. Just going off of what I remember from others doing it.
