High idle problem
Remember what I said. As long as the IVS trigger the ILDING lead the ECM IGNORES the APPS voltage and signal and uses its own idle software. So basically switch number one would be grounded and switch number 2 would be open or showing +5V on the ECM. This tells the ECM to IGNORE the APPS voltage use it idle software which high idle software is part of.
apps-sensor.jpg.315e1c64a4baf8d04f999536
