Checking / replacing relays
Easy way to test relays is take a known good relay like the horn which is a smaller relay and swap it with what is questionable if the problem goes away then the relay failed. Like two years ago I lost my A/C relay I swapped it with a known good relay and A/C started working. The next town I came across I stopped in just purchased a new relay.
