- Replies 9
- Views 11.4k
ecurnes8888 4 posts
Chris O. 3 posts
Mopar1973Man 1 post
Me78569 1 post
no first hand use here, but I know the star scan on the vp trucks can act in the same way as a DBRIII tool. Effectively lets you test anything that is controlled by a computer.
On the common rail truck they have TIPM (Totally Integrated Power Module) which controls a lot of different things on the truck. The best person I can say to talk to is @Chris O. since he's the site C
Sorry but you got this a bit wrong. Class B, ISO 9141, SCP, Class 2, and KWP2000 all were allowed methods of powertrain communication under OBD II until 2008, at which time controller area
I have heard a lot of rumors about what the dealer can activate with the Star scan tool through the CAN BUS system. I'd like to hear from people that have actually had some features turned on, not from a guy you know or what not. Actual experiences, share your year and what you had done. Some things I've heard (I know some of these are true) High idle, accessory power delay after ignition is turned off before the door is opened, changing the vehicle location to Canada will turn on daytime running lights, activating the trailer lights through the factory trailer hookup. I would like for this to be an easy place to gather information if someone that wants a feature activated by their stealership and is getting pushback, or maybe just a place to learn about what is available in your vehicle.
