- Replies 8
- Views 2.3k
								AkCoastline 4 posts
								Mopar1973Man 2 posts
								Me78569 1 post
								wh82 1 post
Popular Days
								It is perfectly safe to run MPG mode when it is cold. I suggest you wait until the truck is warmed up before going into MPG mode. MPG mode does NOT do anything to fueling. MPG mode actua
								No actually the ECM it cranked up to 19-21* BTDC then the Edge Comp is adding more timing top. It gets rather high timing the lower the IAT gets. Quadzilla is an awesome tool for watching the ECM outp
Just got my high idle switch, super excited!!
Couple questions due to other mods on the truck. Truck has 7x.011 SAC's and edge comp box.
3cyl High idle, is there any reason I should not use it every time I warm up my truck?
MPG setting on the switch, is there any reason I shouldn't use it with my comp box and injectors that are around 100% over?
