Just installed issopro ev2 piro and boost gauges,
Questions what fuse or wire ignition should I tap into?
#2 what wire can I tap into for dimmer....thank you for the help.
  • Replies 6
  • Views 1.5k
don't splice into existing wires..... just a new headache for later.
 Use fuse block add a circuit.
you can get dimmed voltage on fuse 5 and fuse 14 ( i think) is already called gauges.
