Airdog low pressure
50 minutes ago, trreed said:
FASS lol.
Figured
Mines done basically the same, except I think my FASS return line is a little further down, I'll have to find pics to verify. Only issues I get are longer starts when fuel gets below 1/2ish tank when parked on my inclined driveway. That stock return line, like yours is hanging down there, is what I think is causing my issues and I think I'll end up getting a Liberty fuel module eventually as well to get rid of that problem all together.
4 hours ago, trreed said:
I definitely do not expect you to drop the tank to check that.  IMG_3515.JPG.15e76b61aa501b1020efca68d371534e.JPG
This is my basket.  As you can see, the return line ends right above the stock pump location.  Causes wonky pressure readings below 3/8 of a tank.  Stupid thing leaks so much diesel now that i'm giving up and getting a Vulcan Liberty module at some point.
I knew you didn't expect that. I have picture somewhere of the finished basket. I used after reinstalling the basket and the fuel tank to confirm that I DID forget to put a spring clamp in place before install. So i had to pull the tank again to put the clamp into the proper place. :doh:
 Mine used the old pick up for the AD return line and the engine return went in the oe location.
