- Replies 9
- Views 5.7k
woodtrucker 5 posts
dripley 2 posts
Me78569 2 posts
Mopar1973Man 1 post
I would build a calibration tool to see if the turbo responds to commands.
Just as a follow up. I did take to my local dealer where I knew someone and ask them to only look at ecm and sure enough a reflash took care of the exhaust brake issue. Just wanted to follow up in cas
I know some of you may sigh reading the post subject and I really have worked hard to study up on eb vgt function trying to troubleshoot my new truck purchase.
Yeah, I am selling my awesome 02 6 speed that I love for the very powerful/comfortable 6.7 mega cab. My entire family has thanked me for easier travel when camper pulling but I’m chasing down a no eb condition.
Me7....has put a great article out on calibrating vgt so I am now getting the confidence to proceed with pulling off actuator and check for manual actuation to see if things are bound up. Here is how I’ve arrive at this juncture.
-no eb function at time of purchase
-perform service on overhead pops up, did ccv delete and cleared that issue but cc pressure code still shows up on H&S. People tell me this is expect on early 6.7 with H&S. (Unrelated to eb not working I know)
-then I pulled back pressure line and sensor for cleaning, still no ebp reading
returned truck to stock and found the code lit for ebp sensor bad.
-dropped $102 for replacement sensor and now ebp sensor works. Still no brake.
-considering the set up to calibrate vgt so I can pull actuator and check sector gear function. If locked up, I’ll tear down for rebuild.
-this should confirm if actuator works vs nozzle ring locked up correct?
any other suggestions beside a new upgraded turbo? I want eb function for camper towing. Thanks smart cummins people!
