Turn Cruise on; the ABS and Brake warnings come on.
Dieselfuture,,
No, I have not.  My sensors are unique to say the least.  Please see picture above.
And I cleaned up the tone wheel and removed any excess grease I found.
I checked the routing of the sensor wires, ensured all connections were tight.
Went into it pretty cautiously after reading Mike's experience.
I see, it's two wheel drive, so are the bearings serviceable then? If they are try to repacking with fresh grease and make sure they're adjusted the right way. And if they're not the maybe they're just loser with time and there is enough slop between tone ring and ABS sensor and that's what's triggering the light. I'm starting to think that might be my problem too.
I serviced the bearings when I installed the new sensors and there is no excess play.
So far, the ABS and Brake light only come on when CRUISE is used.  I took it into town today (32 miles RT) without CRUISE and no ABS or Brake lights came on.
Always something to work on.  :)
Thanks.
Leaky
