Poor fuel mileage, dead pedal, CEL on and off
Sometimes if I'm concerned about rust after cleaning a ground like under frame someplace I paint it with few coats. Connection is already made and there is no way paint will get in between ring terminal and body/bolt where it's tight, pressure is great there, but it will fill in all voided areas. Jmo.
Guest 04Mach1
Kind of pricey but I use electrical insulating enamel paint on all electrical connections that aren't sealed from the elements, especially frame grounds.
https://www.amazon.com/Glyptal-Insulating-Paint-Aerosol-12-75/dp/B005QQLMBO
I use Glyptal brand. A little goes a long way so a can lasts me a very long time and I never have corrosion or rust at frame grounds after sprayed with insulating enamel.
