Gutting cab/removing wires. 2000 Ram 2500 cummins
On 10/6/2018 at 12:12 PM, Dieselfuture said:
I got it off Craigslist locally and then send it to Florida https://autocomputerspecialist.com
to program it to my truck and enable 3/6cyl high idle. So first they told me I had a problem with pcm, but after I explained them again and again that my truck is fine with original ECM they said then there's something internally wrong and need to be fixed. I'm going to talk to the guy that part out the truck and see if he can remember anything, I know the engine had a knock like a rod knock so not sure if it's related to ecm.
They are on the list of reliable builders, I'd be hard pressed to think that there's is something wrong with almost a dozen positive rebuilds down.
They did what they were supposed to, I'm not complaining about it a bit. I took my chances gambling with programming a used and unknown to me ecm.
