DT/DOR track bar
I’m specifically looking for bar length when using the DOR/DT style mount. It’s a straight bar not the typical 3rd Gen conversion. I tried to deal with DOR but they didn’t want to do anything but sell me the entire kit. I ended up getting just the mount from DT which still costed nearly $500 after shipping and US-CDN conversion.
1 hour ago, Stormin08 said:
you are gong to make it adjustable correct ?
it shouldnt take more than a couple hours to fabricate,
have materials ready...install bracket and measure...maybe trim to length and weld insert.  Paint.
I already have an adjustable bar built on a Chevy that doesn’t need to have it so I’m hoping I can use that hence the need for measurements.
37 minutes ago, notlimah said:
34in for the bar (not including threads or locknuts)
38-1/8th from center bolt to center bolt
Both are approximates give or take a bit but that’s about as close as I could get measuring/holding myself.
Okay great thank you! Is your truck stock height or how much lift does it have?
