Heater core Hell
3 hours ago, pepsi71ocean said:
Do you have a wiring diagram for this?
Thanks @IBMobile ^^^^^
Make sure you go through the whole tread, there were more than one option on doing it. As you'll see i was a bit confused but in the end did cut the right wire, :thumbup2:
Edit
Now I'm thinking about adding another switch to disable blower motor. On longer hwy travels there's enough air moving through that I don't think blower needs to be on at all. This would be beneficial in nice weather, where no ac is required and not to cold where you can still adjust air temp hotter and just have the head wind forcing some in cab. I don't like air blowing in my face on 1st speed of blower but if it was half that it may be ok. Idk just another idea, once again on my car that's possible.
Edited by Dieselfuture
