I have always gotten a random P0121 code usually I clear it and it comes back in a couple of months.
But this time I caught it in action with my quad. When the dead pedal happens the quad show the throttle 100% open and stays that way till I push the throttle a couple of times. Has anyone else had this issue?
Also I need to do the W-T grounding mod. Hopefully on my days off coming up soon.
My fuel pressure is 15-16psi, checked for AC voltage 3 months ago and it was good (Will do it again before and after the grounding mod), and this has happened in hot and cold weather, short or long drives.
Edited by 903Dodge
Just an update.
No more P0121. Since replacing the app my cruise control works flawlessly. Before it would either be no throttle or all throttle while cruise control was set.
Drove it 700miles in 3 days and all is well.
Thank you you for the help.
