Interior hardware
Needing specs or something close to the following
- metal dash frame to fire wall screws/bolts I think there's 5 or 6 of them up across the top
-the 2 little nuts that secure the port with all the HVAC vacuum lines, threads onto two little plastic nubs.
Gonna go to the hardware store fri, I hope someone has an idea on the size at least, pics work too. Thanks fellas!
Is the frame mount just like a M6 or M8 or some type of machine screw or self tapper?
I think the nuts for the vacuum pod deal is those thin nut-look-a-like things. Maybe lowes has those? Oriellys?
