So many tow mirrors to choose from.
I just fitted a pair of these
K SOURCE 60180C {#CH1320307} Textured Black Info
Towing Style; Left; Heated Power Foldaway; w/ Towing Package; Spot Mirror; flip out Head
from Rockauto. if you search on 1998 they come up as seperate left and right, if you search 2002 same mirrors are either individual or as a boxed pair, the pair works out a little cheaper but to be honest by the time they get here they are expensive, both mirrors were $243 ish, shipping $53, well over £350 by the time they got here.
They don't vibrate, fit was ok but not quite right especially drivers side as there is a screw and a clip that secures the mirror wiring and it just doesn't allow the mirror to fit flush to the door, I just removed the clip and screw I also had to trim a little off of the back of the mirror position switch as it was catching on one of the nuts but that was only a shaving, the spot mirror is top outside until folded out then bottom outside, visibility seems good but not driven it yet
