Well 52 psi
  • Replies 21
  • Views 6.2k
  • To put it in perspective for you.   We have had tunes posted here for a few years now.  There have been nearly 4,000 tune downloads.  The tuning articles that have been posted have generated
  • Most issues are related to an aging platform.  Worn our sensors, failing xyz etc etc.  The quadzilla needs good inputs to run well.  more so than other tuners for a 2nd gen because of the on the fly m
  • A bigger turbo will make smoke worse on the bottom end as a bigger turbo will take longer to light.     Your smoke issues are %100 related to the smarty. Period.
if one takes the time to read what each setting changes does, it isnt hard at all...the end user views were mad to be very simple visually, and adjustments even easier.
i only recall 2, maybe 3 trucks that for what ever reason...just didnt like talking to the quad. but like stated, it can also act a s very informative diagnostic tool, you can literally see sensor failing if you pay attention.
