finding wire connection location need some help
OK guys I had A guy  put on new fenders and repaint my 01 well all the wires did not get put back on and or connected having trouble on location of a couple wires go can someone post a pic or give me a location where these wires go thanks in advance this is on the drivers side of truck
The larger one looks bad enough that it should be changed to a new ring terminal.  If one is like that it is likely more are going to need attention. :2cents:
Edited by JAG1
yes for sure thank you I did actually did replace that with new ring terminal cause when I started cleaning it up things were getting worse so i changed it. yeah I know working on going over them and cleaning and or replacing them as i go been working on electrical now for a week thanks for the input this forum is such a great place.
