- Replies 19
- Views 7.5k
joeld79 5 posts
joeld779 5 posts
dripley 4 posts
Tractorman 2 posts
I have to agree with @Tractorman. The nose up/down thing is a red flag. It does not take much of a opening while pinching those lines to let air thru. I also curious what check valve you replaced on t
You might try loosening the nuts on the head at 1, 3, and 4. Prime the system then until you get a good flow of fuel to them and tighten them as they do, then keep cranking. It will run rough until al
Ok I have been trouble shooting a hard starting/long cranking issue for almost 2 years now, owned the truck since 2006
2001 24V HO
AIRDOG the week i brought it home and ever since
Edge Stage4 Jammers I think injectors
Newly rebuilt NV5600 (ChaCh$$$ng)
196K
nose downhill, no problems
level, takes over night
nose high, takes a few hours
to require a priming sequence necessary to start the truck, worse in the cold weather
Lots of informative helpful threads out there and I have been through them all
Last night pinched just at the VP44 inlet and just after the T return lines from the head and the VP44 and closed the lines
This morning it still would not fire until priming sequence
Where would the fuel be going?
Is this a sign of the VP44 going bad?
No codes stored
TIA
Joel
