I dont know how to read the oil properties but I have 2 examples and wonder which is better.
Example A
TYPICAL PROPERTIES
SAE Grade 15W-40
Specific Gravity @ 60ºF/15ºC 0.872 – 0.88
Viscosity @ 40°C cSt (ASTM D-445) 102 – 108
Viscosity @ 100°C cSt (ASTM D-445) 14.00-16.00
CCS Viscosity @ -20°C cP (ASTM D-5293) 5,700
High Temperature High Shear Viscosity 302°F/150°C cP 4.3
High Temperature High Shear Viscosity 302°F/150°C cP after 90
cycles shear (ASTM D-7109) 4.0
Mini-rotary Viscosity-TP.1 @ -25°C cP (ASTM D-4684) 20,500
Mini-Rotary Viscosity @ -20°C, cP -180hr sooted oil sample
(Mack T-11A ASTM D-6896 15,236
Viscosity Index (ASTM D-2270) 154
Flash Point °F/°C (ASTM D-92) 440°/221°
Fire Point
°F/°C (ASTM D-92) 490°/254°
Pour Point
°F/°C (ASTM D-97/D-5950) -38°/<-39°
Sulfated Ash Content % Wt. (ASTM D-874) 0.951
Total Base Number (ASTM D-2896) 10
NOACK Volatility (ASTM D-5800)
% Evaporation Loss @ 250°C 9.5%
Shear Stability % Viscosity Loss – 90 Passes (ASTM D-7109) 9.96%
Foam Test (ASTM D-892 Option A)
Sequence I 0/0
Sequence II 0/0
Sequence III 0/0
High Temperature Foam Test (ASTM D6082 Option A) 0/0
Sequence IIIG
% Viscosity Increase @ 40°C EOT 75%
Cummins Bench Corrosion Test (ASTM D-6594)
Copper increase, ppm 8
Lead increase, ppm 27
Tin increase, ppm 0
Copper Strip Rating 1a
Example B
TYPICAL TECHNICAL PROPERTIES
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
15.6
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
114.9
144
CCS Viscosity @ -20°C, cP (ASTM D-5293)
4677
Pour Point °C (°F) (ASTM D-97)
-36 (-32)
Flash Point °C (°F) (ASTM D-92)
232 (450)
Four Ball Wear Test (ASTM D-4172B: 40kg, 75°C, 1200 rpm, 1 hr) Scar, mm
0.35
Noack Volatility, % weight loss (ASTM D-5800)
9.4
High Temperature/High Shear Viscosity (ASTM D-4683)
4.4
Total Base Number
12.1
  • Replies 5
  • Views 2.1k
The bottom oil is thicker, and will last longer based on the TBN. The pour point on the bottom one is a little lower, but that will only effect you if you get that cold.The bottom one is Amsoil PCO, whats the top?
Correct, its the 15w40 semi-synthetic and the top one is Schaeffer 15w40 CJ-4 semi-synthetic. I have been looking for "that perfect oil", since I have nothing better to do until I get back home, and have come accross different brands that looked good. I have 15w40 HD diesel & marine amsoil in my 03 and plan to continue running it but my 98 has 226k and I have been using valvoline PB 15w40 CI-4 but its impossible to find in Texas and I want to try something new. I may just go ahead and get another membership with amsoil again and buy the semi-synthetic for the 98 because im gonna continue to run it in the 03 and I could save on shipping maybe ordering it both from them.
I got me a preferred customer account with Amsoil, thanks Bill.
I have never ran the Amsoil semi synthetic, but I always read great things about it... It has crossed my mind to run it and dump it once a year, vs the AME and running for 15K miles... But the AME is working for me, so why change. Its only .90 less a qt.
I thought this thread was gonna be about "real estate"!!!!!!:ahhh::banghead:
