ABS Module Problems?
From what I remember reading on here, they are set for there own truck. I believe there is a very small possibility that you can switch them and they work interchangeably, but I believe there Vin numbers have to match closely, and there are alot out there. @Mopar1973Man I believe can answer this question much better than I can.
2 hours ago, Alexio Auditore said:
But again to answer @TheGreatWhite, you can drive without the module, you just won't have some of your gauge cluster or miles working while you get it repaired.
Yes you can but...
  • Grid heater will not shut off above 20 MPH so be aware. Battery charge time needs to be extended.
  • Cruise control doesn't work need to be above 30 MPH to set..
  • High idle will work but will not cancel from no speed signal.
  • Speedometer will not work. Lack of signal.
  • Might impact automatic trans being road speed is considered.
