If the Quadzilla Adrenaline V2 software takes complete control of the vp44, what would happen if I flashed the ecm with my superchips flashpaq programmer and put the quad above level 0? Would anything happen or would the quad still keep it's custom timing and/or fueling? I'm just curious as to what would happen and want to see the difference in timing. It would be neat to have the programmer on level 0 and the quad on anything above that.
  • Replies 4
  • Views 1.3k
  • It won't harm anything its just pointless.
  • The quad will over write the timing completely and alter the canbus fueling message per the tune you built.   there is no point in putting a superchip on it as the quad can make a better tune for your
  • Mopar1973Man
    Stacking tuners just turns the throttle into a light switch. By the time you reach 30% of throttle by position the ECM will be at 100%. fuel rate.
The quad will over write the timing completely and alter the canbus fueling message per the tune you built.   there is no point in putting a superchip on it as the quad can make a better tune for your truck without any help.
Thank you @Me78569 So if I do flash it just to compare them to see the differences, it won't do any harm to the VP if I go past level 0 right?
