How much Hp do y’all think say 01 24v with bigger intake horn quadzilla adrenaline v2 tuner duel disk converter stage 2 clutches /fass 165g and  for turbos if there’s anyone out there happen to be running the newish power driven diesel Aggressor 62mm  turbo and and one that’s maken say 550to 650 would like to talk to you about turbo you might be running if possible thanks everyone
Okay thanks for that  just trying to decide what turbo to go to  I didn’t think it would be this hard I was going to go with a Borg sxe364/73/14cm  but then seen the aggressor 62 mm that’s lot cheaper but still good just don’t have a billet wheel   But people ran cast wheels forever and made good power they put the the aggressor on a 12v will stock valve springs and I’m sure some bigger injectors and made 535 Hp on the Dyno and was wondering if it would be any different on a 24 valve
You might be a little laggy with that turbo but it will deliver some air.  If you are just looking for hp you're golden.  But if you're still gonna tow something you might regret it a little.
