Code p0260 popped up today. Can’t find anything on it. Any help would be appreciated. My only symptom is surging at 35-45-55 mph. I’ve had that problem before which was just a loose battery connection but I’ve checked everything I could think of and all connections are okay.
1 hour ago, ColoradoColt said:
Injection Pump Fuel Metering Control B Intermittent (Cam/Rotor/Injector)
Read more at: https://www.obd-codes.com/p0260
Copyright OBD-Codes.com
That’s what I found on it. But I still don’t really understand it
belive you are looking at a 3rd gen or  newer code maybe.
the 460 is a fuel level sensor code and the 236 is a MAP sensor code.
