I’m trying to figure out the OD cancel switch on my swap. Currently the truck runs great. Pulls my camper great on flat ground and small hills but steeper/longer hills I need the option to take it out of O/D to maintain a decent speed and keep EGT down. I’m sure it’s been done before but I’ve tried looking and can’t find any good instructions on how to wire the O/D cancel switch. Any help would be greatly appreciated
  • Replies 5
5 hours ago, Mikeamyers30 said:
It won’t let me download the file. Is this because I’m not a paying member?
Most likely. Does not cost much to be one. Look in subscriptions and you can see what it takes to have the privilege to do it. I am not sure what it takes.
I found the correct wire (orange/white) and connected it to a momentary switch on the dash and then the other side of the switch to ground. It works great! Just wanted to share the progress
  • Current Donation Goals
    • Raised $20
