Clutch Engaged and Screeching/Screaming
9 hours ago, TheGreatWhite said:
Well, @dripley @NIsaacs @IBMobile,  Seeming how I can spin that center piece about 2-3 inches and it wiggles around.
Can you take a picture of the clutch disk? 2-3" is nuts. Did you drain the tranny prior to removal? If not, do so and see what the quality is. If it is full of metal contamination, then yes, full rebuild is in order.
I have not but I plan on draining it. It's a pretty good amount of rotation in that clutch...
