Looking to buy a Quadzilla here is the links back to Quadzilla Power.
1998.5 to 2000 Dodge Ram Quadzilla Adrenaline $699.99
2001 Dodge Ram Quadzilla Adrenaline $699.99
2002 Dodge Ram Quadzilla Adrenaline $699.99
Adrenaline_Thumbnail__20214.1552428542.1
Firstly you need excel on a computer.
1. Start by opening your datalog,
2. The delete the columns you dont want in the reports
3. select the datarange you want to graph on,  I would ensure you don't select more than 75 ish rows.  too many rows results in a junky looking graph
4. Click insert > then graph > then select any of the graphs down arrows and select "more xxxx charts..."
5. In the chart select, choose "Combo" then choose what sensors have what type of graph.  I like lines except for Canbus Fuel.  Ensure you select Secondary Axis for sensors with ranges above ~1000, IE egt's can be up to 2k, rpm 4k    This will make sure your graph data is viewable.
6. If you want to add data lables, right click line / bar > add data labels
7. If you want to compare 2 data logs, you can copy and paste a dataset that has been select ( step 3) and paste it into another table.
View full Cummins article
  • Replies 0
Popular Days
Popular Days
  • Current Donation Goals
    • Raised $20
