- Replies 11
- Views 1.8k
Dumb A 6 posts
Mopar1973Man 4 posts
IBMobile 1 post
Popular Days
Hey buddy, thanks for your help!!! So I had read about this mod, adding the fuses link to the blue wire and performed this mod prior to installing the refurbished PCM. I will change the 7.
02 ram 3500-6 speed manual 4x4.
If the battery temp circuit is open will this prevent the PCM from charging/regulating? I checked ohms between C1 pin 4 and C3 pin 15 on the PCM and found this circuit to be open.
