Quadzilla with an HO motor
- Replies 9
- Views 3.8k
jag 3 posts
Silverwolf2691 3 posts
Mopar1973Man 2 posts
LorenS 1 post
So to be clear i'm not asking about the timing difference in the pump..
@Mopar1973Man, with all of the experimenting and tuning you have done, what would the raised compression in an HO motor do to the timing with the quadzilla? I think people can forget that the motors aren't just a pump difference. It's also pistons, injectors, and compression ratio. With the HO motor being 17:1 versus the SO's 16.3:1, would this make a difference enough to have to adjust the timing?
Side note: does quad allow half steps/part of a percent in the canbus sliders? my truck lurches a bit when I go from +1 to +2 in the percentages..
