Gen 3 track bar conversion
If you could hold a blum bob through the ball joints. String going through each at the center. Thats castor at zero.
Lower ball joint forward is positive castor good driving characteristics.
Lower ball joint to the rear is negative castor and shitty driving characteristics
  • 3 weeks later...
Something I should look at on Thor (2006 Dodge). Being its got a leveling kit in the front end and no other supporting mods like adjustable track bar or lower control arms that are adjustable. Handling is OK but kind of darty and already experience death wobble once! As you lift these trucks the axle moves down and the caster becomes more negative. Then the thrust angle is typically altered because of the track bar is now to short. 2 inch leveling kit.
