Batteries tested good, all right.   Next, even though you jumped the cables it would be good automotive practice to do a voltage drop test on them.   If the cables pass then remove the starter and bench test it.  In the video he says a drop of up to .5 volts on the positive cable is acceptable but 3% of 12 volts, 0.36v, is better.
Edited by IBMobile
