Brother's truck, drivers door functions and brake lights dont work
My brothers truck has no power to
- the radio
- the power windows
- the door locks
- and dome lights
he also has no power to his brake lights.
Every now and then though he gets them to turn on while driving or moving a connector. Haven't had a chance to go and see what connector he's referring to. My first thought was the IOD fuse but it gets power every now and then. All of those circuits I believe run to the in dash fuse panel. Is there anywhere else that they connect to?
2001 Ram 2500 p24v dually conversion, slight basket case
Luckily it was an easy fix. Under the dash where the large bolted in connector is, there is a second smaller "normal" style connector that had come loose. that fixed everything but the brake lights. Turns out he blew the fuse under the hood. Such a simple fix for the windows that cost him an inch of water in the truck..
