- Replies 51
- Views 7.9k
teknic 30 posts
Mopar1973Man 13 posts
Great work! 5 posts
Dieselfuture 2 posts
All right i will add it to my todo list while diagnosing this.
Because the bus is active and talking those voltages fluctuate. During a very long idle state which is very unlikely the voltages will settle.
Lol I threw an ECM at it once hahaha but I tested before that too, just not as thoroughly. Think I just got a badly rebuilt ecm. On the bright side I now know a lot of the wiring. I’ll definitely keep
Hey,
ive got a 2001.5 2500, 6-speed truck.
intermittently my tach/oil press/water temp gauges will stop working. Typically when this happens my engine also has a quick “kick” to it like it shuts off and jumps right back on. I never get the “nobus” message on my cluster.
if I check my codes I have p1693, p1694, p1698. Also randomly a p0501 code and ABS light.
I replaced my ECM for this issue 1-2 years ago but it didn’t change anything, but I used a reman one so not sure if it’s quality. The issue never went away though.
was hoping someone could help guide me through what wiring to check, or really just help me determine what my issue is.
I believe I’ve monitored my RPM with my zedge before and when my tach is dead the RPM still works on there as does Oil Pressure, but the Water Temp just stays in one spot until the gauge comes back to life on the dash.
any help is very appreciated, oh and I have no access to a DRB3
