- Replies 14
- Views 2.9k
wil440 8 posts
Mopar1973Man 4 posts
IBMobile 2 posts
Truck passed it's MOT check last night all good no faults and no advisories, headlamps a little low but as they point to the wrong side for here I always get told about this, If I set them to the righ
I have just finally resealed the Hydroboost on my truck only had the seal kit for most of this year, MOT (our yearly check) is overdue so as it was leaking and that would be a fail I decided nows the time.
The reseal went ok, had to cut the rod as it's a staked item, I was going to make a threaded joiner on my lathe but decided against that as the inner bore of the input seals are tiny compared to the rod they have to be fitted over to get to their grooves and didn't want sharp threads incase I had to ever reaseal again, anyway thats all done and rod welded back together.
Question is has anyone got a picture of the accumulator looking right in it, specifically how far does the piston sit down in the casing as mine is over 1/2 way down, I think it has lost it's pressure, the other question is if it is toast then where do I get one from ?
