Well i bought my 2001 dodge 2500 quad cab 4x4 about 1.5 months ago and have already replaced lift pump, vp44, and radiator clean from puck bottle. Last night i was in my way home and front wheel bearing went out, dang near lost a wheel, that was another $300.00 for a part. so i checked thr other side it was good and i will change it in a couple months due to money, any way took the other side aprt to check and grease the brakes pins and guess what no pin bushings on one side and dry as a bone with almost new pads. I don't understand how people think there mechanics and not do the job correct. Now the question the abs light came on when the bearing came apart and now the light stays on for 3-5 mins going down the road and then shuts off. Is this correct?
It probably means your other bearing is not far behind the first one. that is how mine went. i had a little noise and was not sure what it was until the abs light came on. i replaced that one and the second one went out 3 days later with no warning. i am no genious on these things but it sounds very familiar.
dang that stinks..most important is that you are alright...and these vp trucks can be a money pit also.
