The project starts as soon as I feel like braving the weather.  Main point is to prevent the OEM grid heat nut from finding it's way into cylinder 6.
I am not a huge Banks guy but the parts look well made and everything I need is here.  Huge thanks to @dieselautopower for the parts!
  • Replies 23
  • Views 3.9k
  • well I think it is in.   i need to let me phone charge before I can check for codes etc, but overall good.  Few minor complaints that I will document.
  • This morning the thermometer is reading -20*f.  Truck fully cold sitting outside started without much hassle.  Idle was a little rough for ~60 seconds then smoothed out.   I feel better about the inta
  • I was able to test the intake heater down to about 0*f today.  Truck is noticeably harder to start now, but not hard to start if that makes sense.    Here is a picture of the OEM grids with
Has the killer grid heater bolt fixed with later 4th Gens?  I picked up a '21 3500 and thought I heard Doge had fixed it.
It’s still a potential issue. Doing the bolt wiggle test at each oil change is recommended.
