Anyone care to diagnose this click sound? All the controls on the steering wheel are working (cruise, horn).
  • Replies 6
  • Views 807
  • IBMobile
    IBMobile
    Or it could be the cam on the steering column that cancels the switch.  Used parts from a 1500 will work for replacements.
  • Tractorman
    Tractorman
    Sound coming from the turn signal cancellation mechanism?  It is about the right position of the steering wheel for the noise to occur.   - John
  • Mopar1973Man
    Might pull the multifunction switch to see if something is broken.
- John
It definitely has that same click you get when the blinker resets after you turn (that function is still working normally). I’ll look into the multifunction switch and see if anything obvious is happening.
