Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
I want to thank Mopar Man and all of the members that have shared their knowledge, experiences, and wisdom in our endeavor to maintain and perfect our Ram Cummins. You guys have a real passion for these machines and your willingness to share and help strangers is a fine example of the type of individuals you are! Cheers to all of you!
I have been learning from this site for several years, first as a non member and now as a subscriber. If I look hard enough I will find the information I need to solve all the different issues I have taken on with my Ram. The expertise and technical insight I have gained from all of you is beyond any expectations I ever had. Some of the articles and write ups from Mike & W-T regarding electrical alone have left me thinking and re-reading those articles several times to fully understand the information they were sharing.
A couple of years ago I went after the oil leak at front crank seal and gear cover gasket, while in there I realized that the gear cover to block seal was leaking but I wasn't prepared to pull the cam and needed the truck back in use. The leak has become worse recently and I hate leaving oil on the ground when I park. Question #1 Must I completely disconnect and remove the injection pump or can I unbolt it from the gear cover housing after pulling the gear drive and remove the cover. #2 If I remove the mounting bracket and bolt for the vacuum pump and power steering pump and unbolt from the gear cover can I leave vacuum pump and ps pump bolted together? #3 What are the chances the tappet cover will start leaking in the future, no leak currently. Just fearful that if I'm in this far for the gear cover leak should I keep going and do the tappet cover as preventive or just hope for the best.
I learned a long time ago that I would rather work on the Ram in the shop than on the side of the road and try to be proactive with preventive maintenance. Your feedback is greatly appreciated.
Cheers!
