Anyone able to get me some location dimensions off the nv4500 so I can place the boot right?
  • Replies 10
  • Views 1.4k
  • Royal Squire
    Royal Squire
    You owe me a ride when truck is done 😁😁
  • PilotHouse2500
    PilotHouse2500
    That's ok, kinda figured right now it'd not be you.  I don't know if it REALLY matters TOO much for overall location.  I was planning on centering on the gear shift and let the TC fall where it may.
  • PilotHouse2500
    PilotHouse2500
    Right, and I plan on doing that...but I need to know where to weld a "ring" (thicker version of black thing in pic) to screw the boot and cover plate to.
13 hours ago, Mopar1973Man said:
I wish I could help. I'm down in Ontario OR. If I wasn't doing my cancer I'd be in the shop getting those measurements. Sorry.
That's ok, kinda figured right now it'd not be you.  I don't know if it REALLY matters TOO much for overall location.  I was planning on centering on the gear shift and let the TC fall where it may.  I just don't know if that is a problem or not (cause I won't know untill stuff is welded up and painted), just hoping someone has a number/idea before I start making parts become one via MIG.
I've seen a lot that have a big hunk of foam with a hole cut in the middle that fits over the shift tower and a slot for the 4x4. That is sandwiched between cab and tranny. It blocks some of the noise.
  • 3 weeks later...
well I poked at it the hard way....I put the parts on and tried to find hte best location possible.  Seems that I needed to pull the mounting ring back a bit (off center FTB now) to make things "work".  I'm also guessing I might have the tunnel lower to the tans than woudl be stock on a gen 2.
So back up question, can someone share a pic of a gen 2 shift/TC boot installed?
@PilotHouse2500 Sorry I meant to get you a photo today but forgot. It will be the weekend before I’m back home. Photo will be of a V10 truck which I believe to be the same. Hope that will be soon enough.
Just checking to see of you had a chance?  I put the boot on and did my best guess,  I CAn cut it off to remove if I'm way off.   I do think an issue is how far apart the tunnel height is off the top of the trans ( I might have to space it up).  Still hoping to can pull thru for me.
