ATTENTION ALL!
I know its been long overdue to do some background code work to fix some of the server configuration issues. You have o remember I was working on the changeover from CentOS to AlmaLinux and the different control panels from cPanel to InterWorx. I've hit a few walls on getting the server cleaned up. I've got to build a whole new my.cnf for the MariaDB software.
So bare with me I'm working in the background and trying to make this a fast server once again. The other problem is start getting people that want to write articles and build the site information up. Lot more to come soon.
  • Replies 2
  • Views 1k
  • Mopar1973Man
    As for the newer MySQL database software late last night found I've got a bad configuration and the database refused to start. Currently is missing the configuration but default values are close enoug
  • Mopar1973Man
    Just checking in on the server this morning the memory issue and huge swap file is now stable and not wasting system resources. The crazy part is the server is VPS (Virtual Private Server) so I'm limi
As for the newer MySQL database software late last night found I've got a bad configuration and the database refused to start. Currently is missing the configuration but default values are close enough right now.
As my search engine Elasticsearch is being tweaked also to improve server speeds since the software was cramming every thing to my 2Gb swap file. Hard drive is slower than memory.
Keep an eye open we are working at it.
Just checking in on the server this morning the memory issue and huge swap file is now stable and not wasting system resources. The crazy part is the server is VPS (Virtual Private Server) so I'm limited to 8GB of RAM and attempt o give every process a chunk of memory so all the software can work flawlessly. Strange but true my server has more CPU than my machine at home but yes the server is a 8 core CPU. Just a matter of keep the server running fast on the software I require.
Did This Forum Post Help You?
