Thanks Diesel, My next question was going to be about the warranty, I was wondering if Air Dog stood behind or gave an excuse, like for me, sorry, not covered because you are running BioD w/ it. Thanks you all for your comments, Dave
before i order my airdog150, i called Pureflow and asked them a similar question. i was told that the pump was compatible with bio, although the 1/2" lines they were using could start cracking if you ran HEATED veggie oil. i also asked if i was required to kill the truck while fueling. no you are not required to stop the pump during fueling.
Just making an assumption here so feel free to shoot me down but carbed cars use similar pressures (actually a bit lower) as does throttle body injection and they typically have a mesh sock pre-filter before the pump and the fuel filter after the pump. It would seem that these pumps are better at pushing fuel than pulling it so it works best and has the least amount of pressure drop when ran in this configuration. I can see the point of vacuum filtration but I would think as long as the filter is of good quality it wouldn't matter.
I will not be running heated WVO, as per Bosch requirements for the VP44, fuel temp to the IP should not exceed 90F. Part of the job of the fuel is to keep the pump cool. CTD spoken here, Dave
